Regarding upcoming end to EU roaming fees.
jamie742617
What is going to be the situation with 48?
How are they going about this?
This new announcement is relevant here:
https://community.48months.ie/t5/Most-Popular-Questions/Going-away-Using-48-when-roaming/m-p/44774#M...
What specifically do you mean?
Previously they have adhered to the relevant rules and presumably they will do so (and have to do so) again.
Hi,
Just curious is all. With 3 changing the length of ther plan from a rolling 30 days to 28 I was wondering if 48 would just simply do away with roaming charges without anything similar to what 3 did.
I guess you'd have to ask 48 support of they have any info but I suspect that they won't be able to say until the changes, if any, are announced generally...
