Off to Canaries - how to ensure that roaming will work?
deeflan
Hi I am heading to canaries. I would like to have roaming. The last time there I had terrible trouble and ended up not having it at all
deeflan
Hi did the connect with someone?
Your post doesn't really make sense - maybe you can clarify what you're trying to ask?
If you need to contact 48 support about something then see the link in my signature below or email them at support@48months.zendesk.com
See here:
But as you can see there some people are still having problems with it.
If your SIM predates January 2023 then you might want to get a replacement in case that helps:
It still seems hit and miss for some reason.
fitzie
I had terrible trouble with Roaming, it used to work then stopped. The answer for me was to order a new sim, they have a newer version that works no hassle.
