No network signal
TalitaC5448
I don’t have network . Anyone experiencing the same?
TalitaC5448
I am in dublin
You'll need to post a bit more information than that if you want assistance from the Community Forum.
When were things working ok last?
What changed since then?
E.g. phone software update, settings changes, factory reset/restore, new handset, etc.?
What exactly are the symptoms of the problem?
What exactly do you mean by "I don't have network"?
If not then if you do a search for networks can you see and connect to 48?
If you do have a connection then does anything work?
Calls, texts, mobile data?
