20-08-2026 07:25 PM
20-08-2026 07:28 PM - edited 20-08-2026 07:29 PM
Your post was blank @AnastasiiaN6058 and there's not much to go on in the subject.
If you want assistance from the Community Forum then you need to explain/describe your issue clearly and in detail.
When was it working ok last?
What changed in the meantime?
What are the exact symptoms of the problem?
Any error messages?
Incoming/outgoing calls?
Incoming/outgoing texts?
Mobile data?
What happens when you try to use outgoing services?
Any error messages?
