I changed mobile nd 48 isn't working as it should
EileenH4857
What's not working?
You'll need to describe the problem a bit if you want assistance here.
Are you getting a connection to 48 at all?
If you scan for networks can you see and connect to 48?
Any error messages on screen?
What make and model of phone?
