Esim
henryo2353
Your post was blank @henryo2353 so then exact nature of your issue or question isn't really clear.
If you have a question or issue that you need assistance with from the Community Forum then you need to explain/describe it clearly.
If your query is about 48 eSIMs then unfortunately 48 still don't supply them - only physical SIMs:
Other than partnering with HelloGlobe for roaming data only eSIMs:
