3G not working abroad
aoibhy1
I'm one germany, I bought the guido membership and already have a network selected. The 3G isn't working and whenever I try to use it an alert on my iPhone says ''You are not subscribed to a mobile data service''. I'm going to Bec in Germany for the year but the rates are better with 48.
Check your internet settings.
If the APN field has changed from 48months.liffeytelecom.com then edit it to set it back to that, reboot or switch airplane mode on and off and then try again and see if data is now working.
Many people have had this problem and this tip has fixed it for many of them.
Did that help at all @aoibhy1?
