Internet
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report this post
26-09-2015 01:07 AM
What can I do?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
26-09-2015 10:58 AM
@sb2183 wrote:
Hi, I activated my 48 SIM yesterday and chose the Guido offer. After getting an SMS containing the settings for my Samsung Galaxy S4 I installed both the Internet and MMS settings. Though mobile data and roaming are switched on no symbol for internet appears, even after re-starting the phone.
What can I do?
Hey
Can you check a couple of things for me. First of all ensure you have only the one APN saved. That should be called 48 Internet.
The following settings should be entered under that APN:
Name - 48 Internet
Proxy - leave blank
Port - leave blank
Username - leave blank
Password - leave blank
Server - Not set
MMS proxy - 10.1.11.19
MMS port - 8080
MCC - 272
MNC - 11
Authentication type - PAP
APN type - default,supl,mms
Check that out and if it still does not work get back to me.
If this helps and your internet works then please accept as a solution.
Damian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
26-09-2015 04:29 PM
It is working now!
Great, thank you 🙂
