top up voucher
sethtilson
Do 48 top up vouchers go out of date?
If it doesn't say so on the voucher receipt then I presume not.
But you might need to contact 48 support tomorrow to confirm.
Are you having problems using one?
Did that help at all @sethtilson?
Hi Dalyer:
You are correct ... it says nothing on the voucher about an expiry date but it seems that 48 vouchers DO GO OUT OF DATE.  I contacted 48 via chat and was told that “everything goes out of date”.  When I suggested that the €10 I paid to buy the voucher hadn’t gone out of date I was told I should have used the voucher as soon as I bought it … not helpful.
Thanks for your interest.
Seth
If topup vouchers expire then I would have expected the voucher itself to say something about that or at least the Payzone and/or Omnivend websites to say something about it but they don't seem to:
http://www.payzone.ie/
http://www.omnivend.net/index.html
Maybe the CCCP can advise on whether or not this is legit?
https://www.ccpc.ie/consumers/
Edit: I did a quick Google to see what other operators do but it's not obvious - however it looks like some allow 90 days validity while others allow 2 years. Did 48 say how long their vouchers are valid for?
Hi again:
No, the 48 agent on Chat did not give that information but in fairness I didn’t specifically ask.  He just said it was gone.
I wasn’t impressed by the ‘tuff’, ‘what did you expect’ attitude.
Regards …
Seth.
