membership help
mervyn2233
Hi there I'm currently with 48 on 20 euros a month and I've been getting 5GB data and it used to be unlimited mobile calls and 30 minutes landline calls . I now want to receive to newly adjusted with 8gb and 60 minutes to landlines and 1000 mobile minutes how can I make this happen please?
Thanks
7 REPLIES 7
Just buy it and when your current membership expires you will get the new deal.
You can't make it happen quicker than that as all memberships always run their full monthly course and memberships purchased while a current membership is in place stack to kick in when the current membership expires.
mervyn2233
Thanks . I thought the new membership came into affect in may??? I last topped up on 27th may and received my original older quota
No. Memberships purchased on or after June 10th have the new allowances.
mervyn2233
Ah that's great thanks for your help
fionntacus
Hey guys i can't find the standard membership. i want the standard pls
Can't find it where?
Standard is no longer worth it.
For €10 Guido is better value.
