Roaming
ivanmcc
My membership renewal date is June 6th. I go on holidays on June 10th. Will my Guido membership activated on June 6th work abroad after June 13th ... or is it only Guido membership activated after June 13th?
It'll work on the 10th, 11th and 12th but not after that.
After that only a Guido membership bought and started on or after 13rh will work while roaming in the EU.
Unfortunately the timing looks bad for you.
Maybe, if you contact 48 support, they might be able to do something for you...?
Did that help at all @ivanmcc?
Additional relevant info here
https://community.48months.ie/t5/Memberships/roaming/m-p/44962#M1133
