10-09-2026 11:15 AM
10-09-2026 12:26 PM - edited 10-09-2026 12:39 PM
Yes, if you use up your full EU/EEA/UK roaming mobile data allowance then your roaming mobile data will no longer work unless/until you buy a mobile data add-on.
You won't be charged anything automatically.
You need to buy the add-on manually if you want to continue using roaming mobile data.
See here:
Can I buy extra Data for EU/UK roaming?
Yes! If you've used your EU/UK data roaming allowance or simply just want more, then the 1GB data add-on can be used in Ireland and in the EU/UK when you’re on a plan that has roaming included. To purchase your add on, simply Log in to your My48 >> Flexi Data >> Add ons, or just click here.
