Phone not working
Lilyc9666
My number is0857767605 I need to know about my account.
You'll need to post a bit more info than that.
Was it working before?
If so did something change?
Software update, settings changes etc.?
Or are you just trying to get started on 48?
If so did you activate your SIM?
What happens when you try to use the SIM in your phone?
Any signal?
If you do a manual search for networks can you see and connect to 48?
Any other error messages or useful info?
If necessary you should contact 48 support for further assistance.
By the way, it's not a good idea to post personal information like your phone number in a public forum like this.
