It won’t let me top up
Chloel8066
Your post was blank.
You'll need to post a bit more info if you want assistance from the Community Forum.
What exactly are you trying to do?
Buy a membership plan, buy an add-on, buy cash credit?
What happens/doesn't work?
Any error messages?
Were you ever able to buy stuff before?
With the same card?
Has the card been updated/reissued since it last worked?
If you're using the app then does using the website make any difference? Or vice versa?
