How to get 4G connection?
MaierE8663
Hi I have 10.99 plan but I can not get 4g connection, it’s anyway to get it ??
I presume you mean a 4G mobile data connection?
Did you configure your APN settings?
Text "APN" to 50048 and follow the instructions:
If you still have problems post back with details.
