Activation code problem
bersheehy
I have received my replacement SIM that I ordered through the 'change my sim' page as I just needed a new size. When I put in the activation code it says 'You're already a 48er. What should I do to activate the Sim???
Are you sure that you ordered a replacement SIM and not a new SIM and are activating it as a replacement and not a new one?
Sounds to me like it thinks you're trying to register/activate a NEW SIM.
You might need to contact 48 support about this.
Did that help at all @bersheehy?
bersheehy
Thanks, you are right. I ordered the wrong sim! Replacement sim ordered today! Cheers
Hi @bersheehy
If you contact 48 support they may be able to arrange it so you can activate the new SIM as a replacement.
I'm sure that they did that for me in the past.
Might save time on waiting on the new replacement?
Did that help at all @bersheehy ?
