Roaming problems persist
ac94
Sick to death of not being able to connect to a network whenever I go away while all my friend’s networks seem able to manage it painlessly. Tired of toggling sim application menus and hoping for the best, sometimes works, more often doesn’t. Can’t believe this still hasn’t been resolved by 48. Moving to a grown up network as soon as I get home
What country are you in?
Does anything work?
Connection to local network/signal bars, calls, texts, mobile data?
