Roaming in Poland but data not working
KRZYSZTOFK6984
Hello everyone, I'm new here I would like to ask a question I'm with this network 48 Mobile I'm currently abroad in Poland and I have absolutely no connection to the Internet I'm trying to connect to the world in various ways there's no way do you know any way to connect to the Internet everything is up to date, everything is set correctly and it still doesn't work
What are your APN settings?
The usual advice applies in the context of roaming problems...
