18-12-2023
11:19 PM
- last edited on
19-12-2023
10:59 AM
by
Hi I moved my number 48 but I want to use old number I don’t wanna use 48 numbers because my old number important for me. Please can you fix as soon as possible
18-12-2023 11:21 PM
See here for details of how to port your number over from another provider to 48:
If you've tried that and are having problems then you'll have to post more details - e.g. what problem arose, any error messages etc.
If you want to contact 48 support about this then see the link in my signature below or email them at support@48months.zendesk.com
18-12-2023 11:25 PM
Didn't you post about the exact same issue a month ago?
And you never responded to my comments there either nor presumably did you contact 48 support...
19-12-2023 10:06 AM
19-12-2023 10:09 AM
19-12-2023 10:47 AM
Multiple duplicate threads/posts merged.
There is no point in posting the same thing over and over again while ignoring the questions that I have asked and the suggestion that I have made that you contact 48 support about this if necessary!
18-11-2023 01:54 PM
18-11-2023 04:29 PM
What do you mean what you can't use your old number?
Did you port it from Three to 48?
Did that work or did you have some problem?
