No network connection after porting number
Piyalid3282
I ported my existing number to 48 but now the sim has no network at all
Did you have a network connection before you ported the number?
If you do a manual search for networks can you see and connect to 48?
Did you enable roaming/data roaming which is needed on most phones in order to see and connect to "virtual" networks such as 48?
