Need help to move my number
yithanl8550
Hi,can you help me move my phone number
yithanl8550
I logged into your system several times and couldn’t change my phone number
yithanl8550
You mean here?
What happened?
Any error messages?
See the number porting guide here:
If you have problems after following those instructions then you'll need to contact 48 support for assistance.
aoifec9347
hi 48
Your post doesn't contain any information.
If you're having a problem and want assistance from the Community Forum then you need to explain your question or problem clearly.
What are you trying to do, what steps are you taking to do it, what happens/goes wrong, any error messages, etc?
