I entered the PIN code, but the interface is stuck
zhoux2104
What PIN and interface are you referring to?
What exactly are you trying to do?
If you're entering your SIM PIN on your phone and it's getting stuck then that's probably a phone rather than a 48 issue.
Or are you trying to enter some other PIN somewhere else?
