48EDGE
haow7576
No network after 48EDGE
Your post doesn't really make sense @haow7576.
What is "48EDGE" and "No network after 48EDGE" supposed to mean?
If you have a question or issue that you need help with from the Community Forum then you need to explain/describe it clearly.
