How do I top up using my credit
Kateh8062
I presume you mean how can you buy a membership plan or add-on and pay for it using cash credit on your account rather than using your payment card?
The option to pay using cash credit should appear at checkout time if the amount of cash credit on your account is at least as much as the cost of the item that you're buying.
E.g. if you have €12.99+ cash credit and are buying a €12.99 plan then you should get the option to pay using your cash credit.
If you have less than €12.99 cash credit on your account then you won't get that option and would need to add additional cash credit if you want to see and use the cash credit payment option.
Someone recently said that the option didn't appear for them on the app but did on the website when they used this link:
But I tried it and I got the option to pay using cash credit on both the app and the website.
If you have a problem with this then post back with full details of the issue.
