Having problems with internet connection
KarenH8615
I'm having problems with internet connection with 48, I've been having these problems for a while, I'm now considering going back with either vodafone or three, as the problems I have don't seem to be fixed. It's very annoying I know it's cheap, but seriously to send a message and it doesn't go through, it's not good enough.
You haven't described the exact nature of the problems that you're having.
"to send a message and it doesn't go through, it's not good enough." doesn't really clarify anything.
What sort of message are you referring to?
The first/main thing to do is to ensure that your APN settings are configured correctly.
I would consider deleting any APN(s) already configured and starting from scratch by sending a text to 50048 (contents doesn't matter) and following the instructions to ensure that the settings are correct:
Then I would check the signal strength and do few speed tests to gather some hard data.
I'm also having the same problem
Same reply as before:
You need to explain what exactly the problem is if you want assistance from the Community Forum.
