Does roaming work in Salou, Spain?
LisaOD1019
I need my phone to work while in salou spain, will roaming work? And is the coverage good?
It should work, but...
AlexandreP8956
I'm currently in Alicante and it's working pretty well. I also visited Barcelona, Sevilla and Ibiza this year at worked fine. So I believe you won't have problems, at least not with 48 - if you have problems check your phone settings.
