Search instead for
Do you mean
Reply
Re: Voicemail
‎19-12-2016 04:01 PM
If this doesn't help...
How do I use my Voicemail?
then I think you'll need to contact 48 support about this:
Re: Voicemail
‎20-12-2016 12:49 PM
Posted from Xiaomi Note 3
What is the voicemail default pin code?
‎17-01-2017 03:19 PM
Hi,
I got a call and would like to check if the person left a message.
When accessing my voicemail by adding "5" before my number, it's asking for a pin code.
I never set up a pin code and this is the first time I need to access my voicemail.
Is there a default pin code for the voicemail?
Thank you.
Re: What is the voicemail default pin code?
‎17-01-2017 03:25 PM
If you have never used voicemail before then it's probably asking you to SET your PIN first off?
Have you tried entering a PIN and then seeing if it asks you to repeat/confirm this?
If not then you'll need to contact support.
See here:
[ Edited ]
‎17-01-2017 03:40 PM
Thanks for the link but it doesn't say anything about default pin code.
I did try two times. With my SIM pin and 0000.
It repeats to enter it every time.
I tried calling my phone and I reached the voicemail.
When, when registrering for 48 months, do you have to set up a pin code for your voicemail? I never went through this step.
‎17-01-2017 03:50 PM
Please read the voicemail guide that I linked to.
If you cannot setup your PIN now then you'll need to contact 48 support and get them to sort it out for you.
Your SIM PIN is irrelevant here.
I can't remember if there's a default PIN configured.
You don't set up the PIN at registration time when joining 48 and many people never used their voicemail at all.
‎17-01-2017 04:07 PM
I reached the support and they could help.
Thank you for your time, I appreciate.
‎17-01-2017 04:14 PM
Glad you got sorted.
Announcements
Welcome to the 48Community!
Order a free SIM
Unlock your phone
Ask the community
