Search instead for
Do you mean
Reply
Re: voicemail
[ Edited ]
‎07-04-2014 02:48 PM
When I use *004# I get
Call forwarding
Connection problem or invalid MMI code
I asked 48 support about this but they couldn't explain it.
Do you get the same problem or is it with other codes?
If it's with other codes involving your number make sure that you have the digit '5' inserted in the right place - I think that the tutorial may be wrong in places and not explain this properly. See this thread for more:
http://community.48months.ie/t5/Need-Help/Voicemail-Setup/m-p/23109/highlight/true#M7045
Voicemail
‎30-06-2014 05:31 PM
Can anybody help, how do you set up voicemail
Posted from Apple iPhone
Re: Voicemail
‎30-06-2014 07:00 PM
See here
http://community.48months.ie/t5/Most-Popular-Questions/How-do-I-use-my-Voicemail/td-p/44/jump-to/fir...
Posted from Generic Android 4.1
Re: How do I use my Voicemail?
[ Edited ]
Crew (retired)
‎30-06-2014 08:13 PM
Here is an example of a voicemail-related question that one of our members have asked:
No active membership = No Voicemail?
‎21-10-2014 09:33 AM
Hi,
My membership expired and I just noticed that my voicemail isn't working anymore.
When trying *#62# *#67# *#61# and *004# I have confirmations that everything is active but when someone call they won't be redirected to voicemail.
Is it supposed to work this way ?
Cheers
Re: No active membership = No Voicemail?
‎21-10-2014 10:31 AM
Not sure but generally you need an active membership for most services to work.
Maybe check with 48 support that this is how it works?
‎22-10-2014 10:33 AM
I checked with 48 support and it is the case that you need an active membership for voicemail to work.
With no membership only the following work (until such time as you buy a new membership or your account gets disabled after several months):
  • Outgoing emergency calls
  • Incoming calls and texts
‎22-10-2014 11:19 AM
Thanks a lot!
Voicemail
‎04-11-2014 05:07 PM
How do I turn off my voicemail.
Re: Voicemail
‎04-11-2014 05:14 PM
See this key topic:
Announcements
Welcome to the 48Community!
Order a free SIM
Unlock your phone
Ask the community
