03-10-2014 11:27 AM
These settings work for the vast majority of Android phones, including Samsung Galaxy phones.
Go to the online configurator here and choose your phone on the list, and follow the instructions to set up your internet. You can also try download the configurator app over wi-fi here.
If the online configurator doesn’t work for you, you can try input the settings manually.
There might be slight differences depending on the version of Android you are using.
To change your phone settings:
Fill the Edit access point section with the Internet and MMS settings:
Enter the following settings:
Name — 48 Internet
APN — 48months.liffeytelecom.com
Proxy — Not set
Port — Not set
Username — user
Password — Not set
Server - Not set
MMS proxy - 10.1.11.19
MMS port - 8080
MCC - 272
MNC - 11
Authentication type - PAP
APN type - default,supl,mms
Save and remember to enable data roaming as well.
