If you need to swap your existing SIM to another type of SIM, follow these steps:
- Go to 48months.ie and log in to My 48. Click on Change My SIM.
- Select the Swap my SIM option and hit continue.
- On the “Order a replacement SIM” form, select Trio SIM and enter the rest of your details. A 'trio' SIM is a SIM card with perforated lines on it, so it is a 'normal' SIM, a micro SIM and a nano SIM all in one. It will fit into any type of phone available now. Proceed by clicking on the “Send me my new SIM” button.
- When you get your new SIM: log back into My 48 and select Change My SIM Go to Step 2 where you can register your SIM. You will need to enter the six digit registration code on the SIM card.
Your new SIM should be up and running in 10 minutes after you’ve done this. Your number and membership or credit will transfer to the new SIM.
You can only Swap to a SIM you have ordered through the Change my SIM section. If you use a SIM you have lying around your number and account won’t transfer.
If this post has helped you, click 'Like' to let us know!
