Reply
pin to install internet settings
‎18-08-2014 10:00 PM
Hi i have been using 48 for about a week and now my internet is not working and is asking me for a pin to install the settings can anybody help please
Posted from Samsung GT-S5830i
Reply
Re: pin to install internet settings
Crew (retired)
‎19-08-2014 11:28 AM
Hi @nikki_
When you request the settings for your phone from Tweakker, you get a set of instructions on the screen that tell you how to install the settings. This includes the PIN, here's an example:
1.         You will receive an Internet and MMS configuration message for your phone.
2.         The display shows the "Configuration message" icon.
3.         Activate the top menu.
4.         Select the new message.
5.         Press "Install".
6.         Enter the PIN code 1234 and press "OK".
7.         Press "Next", "Install" and "OK".
8.         Press the "Center" button to return to the main screen.
9.         Your phone has been configured.
If you haven't entered the PIN you'll need to go back and request the settings again. Remember to watch out for the instructions. The default PIN for this is 1234.
Could you pop a reply back to say if this worked for you now? Cheers.
Reply
‎06-04-2021 11:41 AM
How do you request the settings again? And why are they telling me to use "0000" as the pin if I need to use 1234?
Reply
‎06-04-2021 01:46 PM
See here.
https://community.48.ie/t5/Other-Help/Internet-not-working-on-HUAWEI-ASCEND-g6-u10/m-p/34493/highlig...
It's as easy to configure them manually.
In fact, that's the only way that has ever worked for me.
Posted from Generic Android 2.0
Reply
Announcements
Welcome to the 48Community!
Order a free SIM
Unlock your phone
Ask the community
