Search instead for
Do you mean
Reply
Highlighted
Accepted Solution
only connect to 48 on 2g network, not 3g
[ Edited ]
‎21-07-2013 02:06 PM
I can only connect the phone if I set it to use 2g networks only.
can't connect to 48 on 3g. sometimes it shows up in 3g network list, sometimes not.
o2 is there but can't connect to that.
Is there  a problem with 48 on 3g at the moment in some areas? This is in Offaly.
Reply
Accepted Solutions
Highlighted
Re: only connect to 48 on 2g network, not 3g
‎21-07-2013 10:46 PM
What's coverage like in your area?
http://community.48months.ie/t5/Most-Popular-Questions-Knowledge/What-s-the-network-coverage-like/ta...
Do you know of others do/don't have problems with 3G on 48 or O2 in your area?
Did 3G ever work OK for you on another network with this phone?
Can you try another unlocked handset?
I am not a 48 employee so if you need to contact 48 support then use option 3 or the chat facility here.
Reply
All Replies
Highlighted
Reply
Highlighted
‎21-07-2013 11:15 PM
I'd recommend chancing your SIM card on another 48 phone that also provides a 3G connection.
This will tell you if it's a problem with your account/sim card or your phone.
Reply
Announcements
Welcome to the 48Community!
Order a free SIM
Unlock your phone
Ask the community
