Search instead for
Do you mean
Reply
Highlighted
Registering on a network abroad
‎20-04-2015 09:15 PM
I am currently studying in Germany on erasmus and my 48 has been fine until last week. I am on the standard membership (not offered anymore). My problem is registering on a network. Haven't had any problems with it before but it just wont work now at all so my phone is useless.
Reply
Highlighted
Re: Registering on a network abroad
‎20-04-2015 09:39 PM
Hey,
that's strange... to be on 48 it'd require your phone to be unlocked - which is why im having trouble understanding why yours isnt working....
hmm. how many german networks have you tried signing up with?
Reply
Highlighted
‎20-04-2015 09:42 PM
Yea my phone is unlocked! I was just in London for two days and it worked no problem. But as soon as I got back it just won't work. 4 options come up but none of them work - O2, Vodafone, Telekom and E plus
Reply
Highlighted
‎20-04-2015 10:00 PM
You mean it was working fine in Germany until recently and now it no longer works?
I am not a 48 employee so if you need to contact 48 support then use option 3 or the chat facility here.
Reply
Highlighted
‎20-04-2015 10:15 PM
Yep it has been working fine since I got here in October! It is a Samsung Galaxy s3
Reply
Highlighted
‎20-04-2015 10:28 PM
Could some settings have changed when roaming in London that now prevent you from roaming in Germany?
Do you have a current 48 membership?
What happens when you try to manually connect to one of the German networks?
Any error messages?
Can you try your sim in another unlocked phone?
Can you try another sim in your phone?
Posted from Generic Android 4.0
Reply
Highlighted
‎21-04-2015 11:42 AM
Before it was saying error could not register and this morning it has switched to your sim card does not allow a connection. Yep I have membership and credit in my account. No settings changed when I went to London.
Should I send away for a new sim?
Reply
Highlighted
[ Edited ]
‎21-04-2015 12:04 PM
I don't know if a new SIM will address the problem.
Try powering off, cleaning the SIM contacts with a dry/fine cloth and reseating it in case that helps.
You may need to contact 48 support for advice here:
Reply
Highlighted
‎21-04-2015 05:11 PM
I wiped the sim with my glasses cloth and that seemed to do the trick! It didn't register on o2 but its registered now on Telekom. Thanks for all the help!
Reply
Highlighted
‎21-04-2015 05:14 PM
Ha ha. I didn't expect that to work but glad it did! Man LOL
Reply
Announcements
Welcome to the 48Community!
Order a free SIM
Unlock your phone
Ask the community
