Sorry!
I just reviewed your post... i realise now that you should check out the FAQs on the bottom of 48s homepage and select forgotten pin/puk... this should sort the issue!
If this dosent work contact the 48 care crew.
EDIT: adding a link to more info: http://community.48months.ie/t5/Most-Popular-Questions/I-forgot-my-PIN-or-need-my-PUK/m-p/35067#U350...
@burgertown69 wrote:
I misplaced my SIM card, I entered my Puk code a few times but it keeps saying its incorrect
Where are you trying to enter the PUK? And why (e.g. are you being prompted for it)?
Are you trying to get a replacement SIM? If so see here:
Hi, after blocking my pin my phone requested my puk code so I went online to my 48 details to get it but when I entered the Puk code given for my phone it still came up as wrong?
Hi There.
That's odd... you diddint get a replacement sim at some stage? It's something i can't recall coming up on the forum.
You should contact support.
Thanks so much, I will get on to them now
How do i see my puk code online?
Log into your online account and then go to My Details and it's listed down the page a bit.
This key post might also be of use here:
I forgot my PIN..... What now?
