Did you read the guide here?
What exactly is not working?
Please be as specific as possible. Thanks.
Did you read the FAQ?
What numbers are you dialing? (Don't post your actual number here - just pretend it's 0871234567 for example).
What is the exact message?
Does it appear on screen or is it audio on the line?
If necessary contact 48 support for assistance:
Any update?
It's all explained here:
