Search instead for
Do you mean
Reply
Re: Voicemail
[ Edited ]
‎31-03-2015 09:35 AM
I think the built in voicemail option on iPhones is for something called "visual voicemail" and it may not work with all providers.
https://support.apple.com/en-ie/HT201436
If you just dial 171 then you should be able to connect to your voicemail. You'll have to contact 48 support to check if the iPhone voicemail thing can be made to work on 48. If you get an answer maybe post it here for the benefit of others?
Re: Voicemail
‎08-04-2015 09:21 AM
Thank you this helped
Posted from Apple iPhone
Re: Voicemail
‎08-04-2015 10:30 AM
Glad it helped.
Were support able to clarify if iPhone/iOS "visual voicemail" can be made to work on 48?
Voicemail
‎01-05-2015 11:02 AM
How do you set up voicemail on Iphone 5s? Followed steps on the website but says error?
Re: Voicemail
‎01-05-2015 12:11 PM
You mean these instructions?
How do I use my Voicemail?
When/where exactly did you get an error and what was it?
Bear in mind that I don't think that this integrates with the iPhone visual voicemail feature but I'm not 100% sure.
Maybe some other iPhone user could clarify?
Re: Voicemail
‎04-05-2015 01:01 PM
Any update?
Re: No active membership = No Voice
‎02-07-2015 10:23 AM
Morning. I topped up by voucher and can't make a call. Why
Posted from Apple iPad
‎02-07-2015 10:33 AM
What did you top up?
Cash credit balance or membership?
Remember that if you have a current membership and buy a new one the new one does not start immediately - it will only kick in when the current one has expired.
If you have used up your current membership allowance balances before the membership month is up then you need to buy add-ons to tide you over to the end of the membership month.
Voicemail
‎30-07-2015 07:24 PM
Hi,
I've been trying to set up my voicemail but when I look at the fourms it says that when you join it's automatically set up? I can't find a way to activate it!
Re: Voicemail
‎30-07-2015 08:39 PM
Where did you see that it's automatically set up?
That's not my experience.
In my experience you have to configure it yourself to get it working.
See here:
Announcements
Welcome to the 48Community!
Order a free SIM
Unlock your phone
Ask the community
