Search instead for
Do you mean
Reply
Re: Voicemail
‎04-11-2014 05:32 PM
Thanks but it doesn't give the option to turn off your voicemail. It gives you options for greetings only. But thank you.
Posted from Apple iPhone
Re: Voicemail
[ Edited ]
‎04-11-2014 05:54 PM
It does.
It's #004# to switch it off.
The guide doesn't make it clear that it's *004# to switch it on. (And some posts elsewhere mistakenly say *#004# which is not a valid short code).
172 doesn't give me options for switching it on/off - just some other menu options. I guess that's what you got too?
There may be another 004 code to check the current on/off status without changing it but I don't know what it is.
Hope this helps
How do I switch my voicemail off?
To switch off your voicemail you’ll need to use the following shortcode number that you simply dial on your mobile (they don’t cost anything to use):
172 (or alternatively dial #004#)
To check the status of your voicemail if you’re not sure if it’s switched on, dial *004#
When you ‘switch off’/disable voicemail, it stops all calls going to your voicemail. This covers all types of call situations which would normally be diverted to voicemail (i.e. when you don’t answer a call, when your phone is switched off, when you’re on another call).
It's #004# to switch it off and *004# to switch it on.
172 doesn't work for me for switching it on/off - if only gives other options unrelated to switching it on/off.
Re: Voicemail
‎04-11-2014 06:12 PM
Thanks
Re: Voicemail
‎12-11-2014 11:41 AM
Hi Team,
I set my personal greeting(voicemail) but it wont let me switch it on when I input *004#. The error comes back - ''Error Performing Request, Unknown Error, Setting Activation Failed''.. It allows me to turn it of when i input #004# however ' Setting Deactivation succeeded''.
I really need this to be turned, HELP!
Re: Voicemail
[ Edited ]
‎12-11-2014 12:09 PM
Both *004# for on and #004# for off work fine for me on Android 4.1.2 JB.
When I dial *004# and hit call/send I get:
MMI code started
and then
Call forwarding
Service was enabled.
OK
When i dial #004# and hit call/send I get:
MMI code started
and then
Call forwarding
Service has been disabled
OK
If *004# is not working for you then you probably need ask 48 support for advice/assistance:
Guide on how to get help
Edit: do you have an active membership as voicemail does not work without one?
Voicemail
‎31-03-2015 12:40 AM
When I try to set up voice mail it says to contact service provider when I try defaults it says error and won't work can you help please
Re: Voicemail
[ Edited ]
‎31-03-2015 01:35 AM
How exactly are you trying to set it up?
When exactly do you experience problems?
Did you follow the key post on this?
How do I use my Voicemail?
If you did and it still doesn't work then you may need to contact 48 support for assistance:
Edit: this may also be relevant:
http://community.48months.ie/t5/Need-Help/How-do-I-set-up-my-voicemail-to-work-automatically-on-my-i...
Re: Voicemail
‎31-03-2015 03:01 AM
**61plus 003535plus my numberand hash put in and phone button and it says unknown error
Re: Voicemail
[ Edited ]
‎31-03-2015 08:41 AM
You're dialing the wrong code to enable it.
You should be using
**61*+3538951234567#
assuming your mobile number is 0891234567 (or in international format: +353891234567).
Option three
To enable this: dial **61* followed by your voicemail number, followed by #, and hit call
To cancel this: dial ##61#
To check the status of this option: dial *#61#
So if you want to enable option 3 and your mobile number is 089 1234567, dial **61*+3538951234567# and hit call.
Posted from Generic Android 4.0
Re: Voicemail
‎31-03-2015 09:32 AM
This worked but when I press voicemail on phone menu it says cannot connect to voicemail please connect service provider
Announcements
Welcome to the 48Community!
Order a free SIM
Unlock your phone
Ask the community
